Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
just a quick question what size opening is a normal standard internal door casing and door, then what size opening do i build to fit it, is it around 800mm wall to wall what height also?
The most commonly used size where disabled access is not a factor is 762mm or 686mm x 1981mm high. Where you need to comply with disabled access, you need a minimum 800mm clear opening so use 864mm x 1981mm.
You can make door linings but TBH, it’s far quicker, easier & usually cheaper to buy a door lining kit unless you really like woodwork.
