Door restrictor options for composite door
17 Aug 2014
Middlesex
Hi all
I have a composite door that I would like to restrict from opening out more than 90 degrees as it is slamming against an external wall.
The restrictors I've seen online all require a groove in the door for the mechanism to slot into but as the door is composite I don't have that. Also as I don't have much clearance (2mm maybe 3mm) between top of door and frame even if I fitted one like this I think it would catch.
Any other options out there that I can consider?
Thanks for any guidance.
