I am about to fit a cupboard switch in my under stair cupboard which will drive a 9w led light strip which will be ceiling mounted. Before I carry out the work I have a quick regulation/safety question before I complete the work.
All the cupboard switches I have seen (like this) are 240v and 2 amp. As this is 2 amp and the circuit breaker is 6amp at the fuse box then my instinct is that I will need to include a fuse before the switch to stop some idiot in the future extending the circuit or wiring something daft into the circuit?
I wonder whether this is actually required and whether the fuse is only strictly necessary when adding a plug in which someone could plug a device with an unknown load? I am guessing that hard-wired devices do not need such fuses as the fitter should be making the appropriate load calculations to ensure that risks are minimised
I may just put a fused switch in anyhow as I would like a switch to override the cupboard switch so I could therefore use a switch with a fuse built in (like this).
Thanks for your help, I do like knowing the regulations, rules and best practice before starting any work!
Jon
Jon
