Dormer slate side cheeks and soaker upstands
B
blackranger
i have to repair a roof that has a dormer the side cheeks are slate.
The main slope of roof were it meets dormer will have soakers.
What do i do about the soaker upstand?
Do i just tile over the upstand?
Do nail a peice of lead flashing across the upstand then tile?
Agree with CWB. The material you use to cover the dormer cheeks will deal with the upstand.
If however there are faced masonry cheeks in place you will then need to chase in a stepped cover flashing over the soakers the same as any roof - wall abutment.
no faced masonry just natural slate.
its a a very old roof and they have used zinc L shaped along the cheeks of the dormer/hay door to carry the water away. Unfortunately the zinc has cracked in the corner and rotted a roof rafter.(now replaced)
I now need to replace the zinc with soakers, add more slates to make them meet up.
I am no roofer, i understand the principles. So hopefully ill manage it lol.
since the dormer is at the bottom of the roof, can i just remove 3 rows all the way up the zinc rather than removing all the slate from the ridge down?
Then slate hook the top few slates near the top of the dormer(if need be)?
Can it be done ?
is it lazy?
Would the pro's do it that way?
I am not putting felt on.
Use the slate ripper to remove the one above, then remove the slates going down.
Reslate, fitting new soakers, the last slate will need a lead/copper strap to hold it in place.
the sides/halfits of the dorma will probs have to be removed fully as for the main roof you should be able to just take a few out
yes doing it now ......assume its really old as nails are square...stripped the cheeks and taken half the zinc off
probs hand made nails i come across them alot
I am always impressed by a hand made nail...lol Unsure what these are made off/coated with. Its not copper and not all of them are rusty. I assume they are from 1900's
Thanks too all that helped with info. Dormer re-slated and no leaks.
