Hoping someone can give me some advice please. A builder has installed a dormer into our house which I need to finish internally. He has used OSB board with a timber frame supporting this inside. The timbers are 93mm deep and 43mm wide. I wish to put Celotex insulation boards between these timber members, do I need to put an insulation board as close as possible to the 93mm depth of the timber members or is advisable for example to use a 50mm deep insulation board pushing it flush between the members but retaining an air void of 43mm behind. I intend to then place insulated plasterboard over the top to eliminate cold bridging of the cross members. Can anyone advise. Thanks
