Dos Extract Utility
T
tullibody
I have an Extract Utility, it woul be used to extract .PES Embroidery files. It is called PK Ware, Version 2.04 1993. It is installed in dos under c:\designs\mascots. The files I want to extract are on CD :!:
Just to add to what Eddie has recommended, "PK Zip" is the original title of the "zip" archiving algorithm.
Oh, yeah one further point to add you can't extract them to your CD ROM, try something like My Documents, but then you've probably already done this :)
I guess, looking again at your post, you do not know how to use PKZIP / PKUNZIP .... Have a look here :- http://www.biostat.wisc.edu/bcg/sup/mssup/pkunzip.html
Someone has very sensibly explained the use as opposed to what it is.
A neat little explanation how to do the job ... also allows download of PKUNZIP this little dos prog 'extracts' files from a compressed, PKZIP file.
I am sure Winzip (windows based) will handle files created with PKZIP, may be easier than the command line usage demanded by the dos PKWare progs.
P
