Had a quick look but couldn't find the answer on here but apologies if this question is repeated.
I'm going to have a go at dot and dab (never done it before). The walls are 2800mm high and my 12.5mm plasterboard is 2400mm so there will be a 400mm horizontal join. I think having the join at the bottom would disguise it best but how should I apply the boards to the wall ? Will the adhesive hold a full sheet at the top or will I need to fix a batten to hold it up until it sets? Otherwise I could cut and fix the lower strip but if I wait for it to dry it might make leveling the wall very tricky.
Thanks.
Thanks.
