Double Oven
16 Sep 2004
At the minute we have a Single oven/grill. It is Dual Fuel gas rings & electric oven. Can Someone please give me advice on whether it's appropriate to straight swap the wiring when replacing to a fully electric or is life really ot as simple as that!!?
:roll:
It depends entirely on what the wiring was designed to support when it was first installed. If it was just an oven, or if there is no dedicated wiring and the oven plugs into a socket, then it isn't as simple as that.
If it was designed to take an all-electric cooker then it might well be.
You need to know the maximum loading of the cooker, or oven(s) and hob combined, the size of the cooker circuit cable, and the value of the fuse/MCB.
Do a search on the forum for cooker, oven, hob etc - you'll find loads of info.
BTW - have you ever used an electric hob? I'm not the only one who thinks they are despicable, and would never have one - gas is the only acceptable type of hob.
Fair enough if you like them, but if you're making the change without knowing what they are like you may bitterly regret it.
