Yes - you can if you want to. They look similar to light switches, but not exactly the same (light switches on left, DP switches from same m'fac on the right):
if its because the switch in question has a neon be aware that the neon needs a return path to light up. There is usually no neutral at a lightswitch, i guess since a neon is extremely low current you could use the earth but this is considedered to be bad practice.
plateswitch locators are generally wired accross the switch so they come on when the light is off (and the current they draw is insufficiant to light the bulb)
you could do this with a switch with neon but it might be a bit confusing having a neon indicator come on when the light is off.
