Hi.
I´m about to install a central heating in my house.
In each room there will be two radiators (so that heat is better distributed).
My idea was to use a manifold to distribute pipes to three rooms (so the manifold would have 3 "outgoing" and 3 incoming connections.
The piping will be pex.
What I´m not sure is how to connect the 2 radiators in each room. Should I connect them in parallel or in series?
If I connect them in series I care about the second radiator receiving water not hot enough.
If I connect them in parallel both would receive water at the same temperature, but then I have to use "T" connectors for the pipes (which is not the idea when using a manifold...)
Any advice?
Thanks!
Any advice?
Thanks!
