Downpipe moved..
23 Mar 2005
I have just replaced my gutters and down pipes and on one down pipe I have moved it along from the gutter to floor as the old down pipe was going through my lean to and I did'nt want the new down pipe taking this route so I have sealed the hole on the lean to and moved the down pipe.
The problem l have now which I'm sure someone will give me suggestions for , is the rainwater drain is about 18 inches away so at the moment the down pipe is running off a shoe onto the path.
I have a outside door between the new down pipe and drain so I cannot run a piece of pipe along to the drain so l suppose it needs some of the path taking out to make a gully to the drain..
what is the smallest drainage system I could use to sit the down pipe in to take it to the gully..
Also best way to cut into the gully to sit a drainage section in...
Would it crack if I try a grinder on it ..
