DPC
4 May 2004
Hampshire
Dear All,
I've recently removed an internal block wall. All supporting work, calcs and building regs complete. At the base of the wall there was a dpc.
I just want to check that the dpc needs to remain, despite the wall being gone, to protect the new floor. :?:
hanks,
P.J.
Where you patch up the floor, yes this does need dpm under it to prevent damp.
Hope this is what you meant.
Is there a wall under the dpc or the dpc just resting on the footing or oversite ? What is the floor materials ? A photo would help.
Thanks for the info guys.
There's no wall below the dpc, as its on the ground floor. I guess it must be that there is a footing under the dpc and not that the wall was built on the concrete base, otherwise, why use a dpc ?
Actually, I remember theres a membrane under the floor screed aswell, so why would a dpc be needed at the base of the wall (which is now gone) ?
Safe bet, as you say, is to include the dpc when I lay whatever on top - think it will be tiles.
Thanks,
P.J.
