Hi All
I have a reacuring sewer blockage, always happens in the same place. I've had a camera down and there seems to be no breaks in the line. I have (Hopefully) attached an image of what I belive is a problem.
The pipe hole at the top is the main drain, there is also a hole just infront of it. When water goes down the sewer on my property it has to fill up the 'gutter' part before it goes over the lip to the main drain, this causes my line to back up which in turn slows down and compacts 'solids'. This eventually blocks my sewer pipe. The top of the main sewer lip is above the top of my sewer pipe.
The hole in front of the main sewer hole feels like its a dead end but is full of stones (And the odd screwdriver!) some of which I pulled out and you can see in the gutter part. Does anyone know if this is some kind of debri catcher? Or maybe a proper connection to the sewer? If it was the later then all the water would flow correctly and not cause a blockage. I feel like cutting away the lip on the main sewer line to lower it and let water flow correctly.
Any advise would greatly be appreciated.
