As someone that uses a Jetter, I can assure you there isn't much they wont remove. Water pressure alone will remove scale and fat, used to drive specialist jetting heads, they can cut out and remove roots, concrete, and pull back bricks, large stones and other debris in a drain.
You certainly dont argue with them, fatalities have occurred.
