Hi
Would I need to drain dowm the entire ch system when replacing a motorised valve (three port) if there are isolating valves above and below the motorised valve. Above is a 22mm pipe supplying the hot water feed from the boiler. Below is a 15mm pipe rising up from the main pipe that feeds from the bottom of the cylinder coil.
There are no isolation valves on the pipes from port a and b feeding the rads and the tank respectively. These run from either side of the mv horizontally
Any guidance/advice would be much appreciated.
blup
blup
