Drain is overflowing from kitchen
[QUOTE="bernardgreen, . There is ( or ahild be ) a shrap bens in the trap in the trap gully. Roding from the manhole towards the drain can compact the blockage.[/QUOTE]
A "double worm screw" on the end of the rods gets rid of any blockage ,
shopping
shopping
[/QUOTE]
Yeah surely rods and much safer(less likely to bresk a drain ) than a press washer or high powered hose? I think I am going to get one
Remember to only twist the rods clockwise other wise the screwed on double worm could come detached from the rod and add to the blockage. ( it IS clockwise isn't it ? :))
If you chip the concrete from around the cover you should be able to clear it by hand then run a tap for a while.
