Drain type Is it Foul or Rain water
Discussion in 'In the Garden' started by ric1982, 4 Feb 2021.
  1. ric1982
    ric1982
    11 Jul 2018
    44
    Thanks Received:
    Country:
    I was wondering if someone can help identify this for me? (I know its going to be difficult with just pictures but thats all I have as the pipes are under the building). I have inherited this when I purchased this house.
    Does it looks like foul or rain water drain? In one picture you can see there is a rodding point (black squre cover) which goes to foul drain. Does it mean this one is rain water?
    The black pipe is from roof gutter while the gray one is from kitchen. (which makes it difficult to judge for me)
    There are no mention of this drain opening in the architect drawings.
    Edit: Its also in the rear- in garden.
    Edit2 :
    Just looked into the records for drainage and water search and it says following:
    1. Surface Water sewer - Connected
    2. Record indicate that surface water from property drain to public sewer
    Does anyone knows what it mean?
    Is it that surface water (rain water) goes into sewer (i.e. foul drain)?
    The reason for post is that I need to know if I can drain garden's rainwater into drain shown in the picture.
  2. Sponsored Links
  3. footprints
    footprints
    21 Sep 2011
    4,539
    Thanks Received:
    986
    Country:
    Quite normal to drain rainwater into the sewer on existing homes, however my son in law's house has all rain to a soakaway and as a result he got a reduction on his water rates!(y)
    If you have a manhole in the front you can buy a drain dye to put down the line you wish to trace.
    • Thanks Thanks x 1
  4. Ian H
    Ian H
    14 Sep 2010
    7,037
    Thanks Received:
    864
    Rochdale
    Country:
    If you pull the black insert out of the gully then get someone to flush the toilet you should be able to hear it.
    • Thanks Thanks x 1
  5. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
