I moved the washer from my kitchen to the other side of the house, about 15 ft away. I dug up the slab, and ran a new drain line. It hooks into the sewer line just outside the house. It has a good pitch and one 5 ft. section is quite steep as it runs under the foundation. I hooked up an elbow near the washer, but the water backed up. I then installed an automatic vent valve on the horizontal abs pipe after the elbow and before it heads down the drain. It drains fine with a hose, but backs up with the flow from the washer. I cannot figure out the problem, do I need another vent? Could the pipe be too steep?
Please Help
Rick
Please Help
Rick
