Hi guys,
I drained down my central heating system to install a new radiator. Once done, I put the pressure to 1 bar, turned on the boiler, started the central heating and started to bleed the rads of any air. After a few minutes I noticed that the bottom of the boiler started to leak in two places, taking off the bottom plate it was coming from the middle and the far right. The heaters are working albeit taking quite a while to heat up. I have a worchestor 24i junior. Had it installed 8 months ago with new rads and pipework. Any suggestions on what the cause of the leak is ?
