Draining a powermax system
  • Thread starter Thread starter marsaday
  • Start date Start date
M
marsaday
if i drain a powermax 155 boiler and change some rads over can i still use the hot water system ? iy may take me a few days you see.
also can i power flush the system myself by hiring a machine ?
If you are draining the system then I would say no.
And I would say...no you cannot powerflush a powermax, dissconnect appliance and flush system, chemical cleanse the beast.
thanks for reply. i will be sticking on a new vaillant combi after power flushing. do i still need to disconnect the powermax in this case. the plumber will be doing it with me, but is not up on these systems though. i may ask baxi about it.
I would defo disconnect and flush just before you fit new boiler.
Powermax holds a huge store of water so will have to use double if not trebble dose of fast cleanse to get a good effect.
There aint no point of flushing the old beast.
Once new boiler in add fresh cleanser, leave in for a week then thoroughly flush system with fresh water and refill with correct dose of inhibitor.
