Does G3 apply in Northern Ireland - not sure. Anyways it's my own house not a customer, and everything will be electrically isolated with the boiler fully powered off and drained down - but appreciate the need for the accreditation.
Given that the water in the cylinder can't get any hotter ( when heated by a gas boiler )than the gas boilers water flow temperature ,why would that be a cylinder safety issue ?
I've just taken an open vented tank out today and realized it can also vent pressure back up the inlet, i guess thats true in these unvented systems as well? Plus temp can't get beyond the gas boilers output as you're getting at I guess. The sludge in the bottom of this tank was disgusting, can't believe we were using it
Just to close out this thread - I drained the CH down yesterday and replaced the valve and the actuator (added in some Fernox inhibitor as well). Hot water now functioning as normal again - thanks for all the help, it's much appreciated.
