Hi
Can I start by saying I have read the FAQ on "Draining down you CH system", however I have a couple of further queries on this procedure and would be very grateful for any advice.
The background here is that even though I have replaced a faulty motor and a faulty uSwitch in the 3 port valve, I still only have hot water. The "CH Test" shows that the valve is not driving over when both wires are live, so I need to change the 3 port valve. I am happy about changing and wiring the valve, my lack of knowledge is in emptying and refilling the system.
1. There is an isolator in the circuit between the pump and the valve. If I wind this in will it help in avoiding airlocks, or, as I suspect is it more likely to cause problems in draining. Should I be to doing anything with this isolator or should I leave it alone?
2. I have an open vented system with a header tank in the attic. I have a litre of inhibitor. The property is a 4 bed new build with around 14 rads. Is this likely to be sufficient (the inhibitor bottle says it will do up to a 100l litre system)
3. Is there a procedure for adding the inhibitor. E.g., should I just tip it all in first when starting to refill the system, drip it in a bit at a time while it is filling, or do something else? Does it really matter.
4. What is the procedure for getting air out. I assume I start at the rads nearest the boiler and work outwords? Any other tips.
Many thanks.
Many thanks.
