draining combi heating system
15 Jan 2010
Glasgow
Hi , i have fitted a drain off valve on 1 radiator downstairs, connected a hose to drain off, other end i put down a drain ( drain drops down a couple of feet)
but no water comes out , i tried bleeding the bleed valves upstairs still no water, (only the water coming from the bleed valves)
i have a combi boiler upstairs , the radiators downstairs are fed by a manifold microbore pipes droping down to downstairs radiators,
i thought with my manifold system i could drain the 1 drain of radiator & the upstairs radiators , what am i doing wrong
The jumper may be stuck down inside the draincock. Is it a soldered fitting if so did you remove the jumper before soldering?
Did you open the vent on the rad that you were draining?
Are both valves open on the rad that you are draining?
hi, armo74 the fitting I bought was a compression type
opened vent on rad but only for a short time because of the water coming from vent, so opened fitting to release water then opened upstairs vents still no joy
both valves were open
tried this before last week & it drained okay
I would say the jumpers stuck down then.
You may have to take the rad off and attach a hosepipe fitting to the valve to drain down.
Once drained you can remove the draincock and strip it down to check it.
It might also be a good idea when you have the rad off to open the valves into a bucket to make sure there is no blockage.
I just put a cup under drain valve & opened it, water came out no problem,
but when I attach a hose pipe it wont drain
don't understand it ,I tried the hose again & could hear the water coming out (sorted,) don't know what I did
