Draining heating system to alter pipework under ground floor
16 Jul 2009
Hull
If draining a central heating system to alter pipework to some radiators under the floor boards of the ground floor in plastic. Is it advisable to open the upstairs air vents to drain all the water out of the upstairs rads.
No real need to empty the upstairs rads. You can shut them all down @ both valves to retain their system water (if it's all clean) and crack open one of the feeds under a valve to allow the pipework to empty, if you are draining downstairs via their external/internal drain offs. Stops the upstairs rads from flash rusting.
If I don't open the radiator bleeds on the upstairs ones with draining. Would that stop the rads emptying via airlock?
It can yes but for some reason it doesn't always seem to work. Any reason the valves can't be shut down?
They could be yes. Been under the floor who ever installed the Pipework originally has hardly clipped the pipework is sagging and looks really poor.
