Draining heating system
10 Feb 2005
I want to remove both radiators on the top (third) floor of my house. I have a closed (pressurised) heating system fired by a combi boiler, and I understand that I have to drain the system to do this. Given that the radiators in question are at the top of the house, and given the laws of gravity, would it be sufficient for me to partially drain the system, i.e. drain until just the top radiators I want to remove are empty, or doesn't it work like that? Thanks. Also, as I understand it I can cap the pipes with compression fittings after removal, is this easy to do? Does it require specialist tools?
Thanks kevplumb. Obviously once I have capped the pipes they will be full of air - will the heating work in such a situation? (Of course I realise I will need to bleed the remaining radiators as I refill the system, but the highest radiator will now be on the floor below the capped pipes).
