Draining radiators
5 Dec 2012
If I just want to drain 1 downstairs radiator (to replace with new radiator and adjust pipework) and all of the pipework only, upstairs, do I just turn off both valves on all radiators upstairs and downstairs, therefore trapping the water inside the radiator and only draining the pipe work?
Or do I have to drain all upstairs including all radiators if I want to completely remove one radiator downstairs?
Cheers
I am not a plumber...
Is your system on a combi boiler or a gravity fed system?
Assuming the valves are sound then yes you can isolate to reduce drain down time . With an old system I would do a complete drain to remove some sludge and then replace additives when finished .
Cheers
Where abouts do I put additives in to the system?
You can get additives in "gun" or "aerosol" forms.
In both cases, you remove the bleed screw or plug, attach the adapter, then inject the additive it - either using a gun as though squeezing put sealant, or using internal pressure in in an "aerosol" style can.
