draining sealed ch system
28 Sep 2010
Yorkshire
hi i need advice on how to drain a sealed ch system i have a worcester greenstar 24i junior condensing combi boiler there is no drain cock anywhere to be seen
the boiler is located upstairs in an airing cupboard in the bathroom i need to change a radiator in the bathroom to one of them towel radiators can anyone help?
easiest way if you can't find a drain tap
is to turn off both valves on a lower rad
drain the rad
remove it and attach a hose to the valve and open it
repeat at other valve if need be
once its drained and you fit your rad replace the valve on the lower rad with one of these
:idea:
