Hi i am interested in buying a house with an unusual problem.
The house in down in a bit of a sump and the road which is about 40ft from the house is higher by a good 6 feet. Upon giving the house a once over i noticed that there was an unusual concrete plinth that ran along side the house and across the drive and then up the boundary with the neigbours heading towards the road.
After not finding any gulleys under downpipes and no manholes anywhere
I soon realised that bizarrly enough this was the main drain running about 2 feet above ground and encased in concrete. The problem however is that the house is a bad layout and would need extended however doing so would mean moving this drain as it is above the internal floor level. Also where it runs across the driveway it would stop any chance of building a garage.
The best method as i have so far come up with would probably be to leave the existing drain from the road to about 5 feet into the garden to and build/ bury a tank and pump? Then relay the house drains to a sensible level and come into the base of this new chamber/tank. The head to reach the old invert level would be approximately 8ft. I was hoping someone might have done this or installed something similar for somebody else before and have some idea of the cost?
Alternative ideas welcome. Cheers
