My apologies, I posted this first in Building in error.
I have recently had new Halo sliding patio doors fitted. There is a draught under the fixed portion of the door, which the company claim is inevitable due to drain holes in the frame. There is also a draught from the joint between the two centre vertical frame edges where the doors overlap.
Given that the fixed and sliding centre vertical frame sections are the same width, should they be aligned and vertically parallel, such that when closed I can only see the inner section? With mine I can see about 10mm of the fixed frame because the sliding portion appears to not close enough, suggesting that they have been made slightly too large. It seems as if the vertical brush seals are fairly wide apart. The company claim this overlap is correct and is how they are designed.
They have been today to try to fix it, but there is still a draught from both places.
What are the regulations, if any, regarding draughts and fitting standards for such doors?
My 30 year old tilt and slide previous doors sealed perfectly and draught free until the rubber started to deteriorate recently, and I only fitted new as I assumed that standards would be higher now.
