- Joined
- 8 Apr 2023
- Messages
- 2
- Reaction score
- 0
- Country
Hi everyone.
So as many have, I have an issue with my Drayton 3 port valve.
The heating is not coming on unless I do it off the actuator manually.
If I turn hot water off and heating off and then put the hot on first then the heating it works.
I have a Drayton digistat and the receiver flashes if I turn up the temp so I’m geussing this is communicating ok. Once hot water is up to temperature the valve shuts off but does then not move to heating and at this point only works when I move the actuator manually. I had a spare 3 way valve body so swapped this but it hasn’t fixed the body. Would you say this was now the actuator at fault?
Cheers
Cheers
