Drayton MA1 mid position valve replacement
25 Apr 2012
Northamptonshire
Hi
I am in the throes of draining, flushing and adding inhibitor to my heating system.
In the course of this I've realised that I may have a sticking three way valve. The actuator is removable so I've tried freeing it by gently rocking the valve itself back and forth but it seems to hit a hard stop where I think it should be at the HW/CW setting, i.e. the central point.
As the actuator is removable and I'm just about to put inhibitor in the system, which means a full system drain or two, I'd rather start off by replacing the valve body rather than the whole kit and caboodle.
I've been checking online and almost everywhere sells either the whole thing or just the actuator.
I can get the valve itself off ebay but due to work constraints I have a limited window of opportunity to get this sorted. Has anyone any idea where I might be able to get the valve body itself ? The actuactor seems to be fine it's the valve that seems to be the problem.
Oh - just realised - the reason I think the valve is sticking is that when the system is on HW cycle, the radiators get hot. However, when CH only is selected the water doesn't warm up.
Basically time.
The delivery time for the ones on eBay mean that I won't be able to replace the valve before June which will be too late. If I can buy the valve unit before this weekend that means that I can get the valve replaced and the inhibitor in before it gets too warm to get the inhibitor circulated throughout the whole system before the summer.
This is all due to the nature of my work.
Looks like it's bite the bullet time and get the lot then £74 from screwfix at the moment.
That would be magic, need the price and details, have to go to bed now (again as a result of my job was working until 5 am this morning), I'll check again as early in the morning as I can for your reply
Valve now fitted, looks good so far, don't seem to have CH when HW only is selected anymore :D
Will wait and see what happens over the next few days.
