- Joined
- 4 Feb 2008
- Messages
- 6
- Reaction score
- 0
- Country
Has anyone got any experience of the Drayton Simp-l-fit control pack?
My heating system is about 15 years old, Glowworm spacesaver II boiler, never given any problems, but recently refused to fire, none of the switch settings on the honeywell controller made any difference (honeywell thermostats and valve system).
I purchased a Drayton pack as above and fitted it, 4 wire connection to the programmer.
When plugged in the boiler fired immediately, and I now have heating and hot water.
However, if I switch on heating only nothing happens. Switch on hot water and I have HW and heat.
The thermostats don't seem to work, as the hot water gets very hot, and lowering the room thermostat has no effect.
I followed the instructions for fitting the valve, ie move manual lever to lock in mid position. However I notice that when I switch on heating only the the indicator does not move to H, and when switching on HW the indicator does not seem to move to HW. The indicator remains in the mid position. I took off the actuator cover to have a look but did not see anything obvious. Taking the actuator off the pipe, loosening the manual lever, and turning on HW and the indicator moves to HW, turning on H and it moves to mid point.
Have I missed something here? Any suggestions?
Incidentially I tried the Drayton site and clicked support, but this results in an error message, so no luck there.
