Drayton TRV Head locked on '0'
9 Feb 2011
Dorset
I have several Drayton TRV heads that appear to be locked on '0' - ie the off position. Is there some trick to getting them freed so I can turn the radiators back on! Many Thanks
Hi.
You should be able to turn them on, anti-clockwise. I can't see any reason why it stuck on "0".
What do the valve look like?
Dan
you can unscrew the whole head from the chromed ring under head/on valve - then have a look @ it in your hand :wink:
As has been said unscrew the valve and look for the sprung steel pins that can be inserted around the edge to limit the valves
