I took my radiators off to re-plaster my flat and bought new ones to replace them. Each radiator has a Drayton TRV4 valve on. The connector that comes out the side is male and 1" wide. My radiators are these ones http://www.heatandplumb.com/acatalog/Henrad_Compact_Radiator_450mm_High_x_400mm_Wide.html
with 1/2" female connectors. My local plumbing shop told me I must have non-standard Draytons which are 15mm (mine are about 25mm) and he didn't have any connectors I could use. It's now getting cold and I don't want to put my old radiators on and then drain them again if I can avoid it. The connectors the old radiators have is screwed into them and then has a large nut on it to screw over the Draytons connector.
Does anyone know where I can buy a fitting like that? It's either that or buy all new Draytons and freeze the pipes to replace the them, which I really don't want to have to do.
Many thanks...
Many thanks...
