drilled holes in pipe.HELP.
2 Dec 2005
Cardiff
MY PARTNERS JUST DRILLED 2 HOLES THROUGH THE PIPES UNDER THE FLOOR. THESE HOT WATER PIPES ARE ALL EXTREMELY CLOSE TOGETHER , CAN WE USE NORMAL COUPLINGS ON JUST THE TWO PIERCED PIPES OR WILL WE NEED TO DO ALL FOUR PIPES.
compression joints are easier to fit (the ones you do up with a spanner or two) but if on joists they may make floor board proud, or cut small section out and join either side.
better to use yorkshire fittings (blowlamp required) but this means you will have to draindown whole system
and please turn caps lock off, it is SHOUTING
