Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
I have managed to drill through an electrical cable between a light switch and a light. I was considering simply using a connection block to fix it, then plaser over it. is this okay?
NO, since the moisture of the plaster may short it out, you should use a junction box, but that means that you will have to leave access to it, sorry you should change the whole cable
you can crimp the cables and wrap insulating tape tightly around the crimps.It will svae you the mess of chasing the wall and pulling in a new cable the patching back up.
Well - ignoring the (somewhat daft) idea of tape (should be heatshrink tubing, although I would accept that self-amalgamating tape might also be useful), and that the original poster has solved his problem, one way or t'other - what on earth is wrong with (proper ratchet-applied) crimps?
sticky situation.
i am not sure what i would do as i have never had that happening to me.
i allways check behind walls for pipes and wires before drilling.
little things like these can become annoying but not as annoying as the problem you face.
