Hi
Been doing DIY a couple of years now and a recent purchase of power tools means I can sort a few tasks I've been wanting to do. Which brings me to a question around drilling.
I'm looking to replace the rotten fence battens which hold the Arris Rail to the brick pillars. These are hidden behind bushes and so I've decided to replace the battens with metal Arris brackets. My question is around drilling new holes for the Arris brackets as the old screws have rusted with some snapped off in the holes. If I'm using a size 6 - 70mm screw with a brown rawl plug (which requires a 7mm drill bit). I'm told I should drill the depth of the screw (so around 70mm or slightly deeper).
The main question is, is it standard practice to drill the entire hole depth using the 7mm drill bit? Or would it be better to drill a narrower like pilot hole the depth of the screw using say a 6mm drill bit and then finish off using the 7mm drill bit to drill the depth of the plug?
I have a number of projects which involve drilling into brick and after upgrading my combi to an sds, I'd like to get my head around best practice for hole depth and size etc.
