Drilling through a Drylined wall into a steel Lintel
8 Oct 2006
Hi
Hanging a curtain rail has anybody got any advice on how best to do this?, the void between the plasterboard and the lintel is quite small circa 1-1.5cm and its proving to be a real bugger of a job!
Is it possible to use self tapping screws or is the lintel too hard for this?.
PS I hate drylined walls?!
John
Use a HSS drill.
The steel may be a bit thick for self tappers. There are some special screws I haven't used. But you can also drill a hole big enough to push a plasplug into, and use ordinary "wood" screws. They need to be long enough to pass through the part in the steel.
you can use tek screws suitable for going into hot rolled steel, (normal steel) or cold rolled steel if it is the likes of a catnic lintel, you will get these from most fixings suppliers, just make sure the size screw you buy the thread reaches the steel as these screws tend to have a 15 - 20 mm self drilling point, otherwise as johnd says you could just drill with something like a 4 mm hss bit and screw a 10s wood screw into it, if you go for the tek screw option make sure you either get a tek head to drive the screw in (8mm nutsetter) or get the tek screws with the pozi head!!
