Dripping mixer tap
12 May 2007
Cheshire
I have a mixer tap and it drips all the time, i have changed washer in cold tap but it still drips took apart hot tap but this is different, ie no washer. Is it the cold side or hot side causing problem? please help
Are you talking about O ring replacement on ceramic tap inserts? If ceramic fittings the replacement of these is the only real way of repair.
it has like a blue mesh attachment ,nothing like the cold side. i have not really studied it but should it have a washer same as the cold side
Don't suppose their are any isolator valves below the sink to isolate the supply pipes one at a time to identify which one is faulty?
