- Joined
- 26 Feb 2024
- Messages
- 6
- Reaction score
- 0
- Country
Hi Guys,
I hope you are well.
My current ceiling is concrete and I would like to drop my ceiling to so that I can add spot lights. I will be adding 2x4 around the perimeter and then add 2x4 joists 40cm a part. My only concern is that I my room size is 380.8cm x 392cm. I live on the top floor so I do not think I can get a 4.5m 2x4 pieces of wood up here.
Could i get a 3m 2x4 pieces and then cut a smaller piece to make the difference?
If so, how will I join the 2 piece of 2x4 to make the distance of the room?
Will this create sag?
Also what is the best and safest direction to run the studs.
I will only be putting plasterboards that weigh 28kg per board and 9 spot lights.
I have attached the room layout for reference.
Thank you in advance!
