Hi all,
I'm having an extension built at the moment, and part of the works involves moving the oil boiler into a single skinned block outhouse that is adjacent to the house.
Building control aren't interested in the boiler cupboard (for want of a better term) as there isn't going to be a rad in there and the door connecting it to the house will be external grade e.g. have required thermal properties - but I'm planning on dry lining it to make it a bit more presentable (currently raw blockwork).
From reading this forum I think I need to dampproof the walls and then hang some foil backed plasterboard which leads me to the following questions:
1) Damp proofing - the shed/boiler cupboard has a hefty slab of concrete for a floor which the builder is reluctant to dig out as the room is not subject to building regs. He is going to apply bitumen to the floor then some self-leveling compound to bring the floor to required height (the slab is less than 25mm lower than the floor level) - Can I apply the same bitumen to the walls to damp proof them?
2) Hanging the plasterboard - should I dot-and-dab the plaster on to the bitumen layer or should I frame it with treated timber.
3) if hanging plasterboard on timber frame (probably better as I'm handier with a drill than I am a trowel
) Should the frame be built off the wall or attached direct to the wall? I ask this as the cupboard is only 4' by 6' and building a 3x2 frame set off the wall seems overkill!
I found this site whist googling: http://www.worthing.gov.uk/Planning...anceNotes/25GarageConversions-WallTreatments/ in which option D lists damp proofing then dot-and-dab but fails to mention what is suitable damp proofing hence Q1 above.
Thanks in advance.
Ant
Thanks in advance.
Ant
