Dry lining corners
30 Mar 2015
I am planning to dry line a room using plasterboard and then tape and compound joints (3 coats) sand it down - followed by emulsion.
I can’t skim but am hoping to achieve a good finish with the above approach.
Q. Should my wall corners be taped and compounded or should I use some sort of mesh corner? Same question for the window reveals please.
Thanks in advance.
Thanks. Can I please confirm that you use these in the internal corners on the wall and also that they are suitable for joint compounding and not skimming as I am planning to dry line the room and then paint - without skimming
Oh and another thought, if the internals wall corners are not 90 degrees (typically the case?), am I better of using tape as opposed to these?
I assumed that there would be corner beading specifically for dry lining purposes I.e. where skimming is not being applied.
I think most new homes opt for this approach as opposed to skimming walls?
Don’t believe that’s the case about new builds, commercial properties maybe.
skimming provides a more durable finish.
Yes, but isn't it also prone to cracking whereas dry lining doesn't have that issue? That's not the reason why I am not intending to skim. Its more a case of, not feeling competent and part of me thinks that I should be able to achieve a decent enough finish with dry lining.
On the corner beading, is anyone aware of one specifically for dry lining purposes?
