Drying out old plaster - old leak fixed
11 May 2010
I have a 100 year old house.
We have a flat roof which was leaking (perhaps for years) but is now fixed. We replaced the roof.
The internal plaster showed signs of damp and I removed the plaster.
Small area of 1 metre square
However, I now have some old damp internal brick work, the internal pointing is poor , dusty - disintegrating.
However, I do not want to do a major job - it would be complicated!
I believe that the house is very structurally sound.
The question is :
Could I just dry out the damp brickwork/pointing and re-plaster. How would I dry it out ? Could I use a blow heater?
What about using batons on the bricks with marine ply on top and then plastering the ply?
All suggestions appreciated!
I would let it dry out itself naturally. A good draught will dry it out much better than a blow torch. Once the brickwork has dried out, give it a good clean off,, re-point any areas that might need it, then scratch coat the area with a 4 to 1 sand and cement mix, with a waterproofer/plasticiser in the mix,, just in case any efflorescence/salts come through. Then you can replaster the area.
Plastering onto ply?,,,,,, any ply?,,,,,, NEVER. It'll fall off in sheets.
Plastering onto plasterboard,,, no problem,, maybe that's what you meant.
A final question in the matter.
There had been a leak from a flat roof.
However, the flat roof was replaced about a year ago.
Meanwhile the brickwork,pointing and plastering had got damp.
Even though the roof was replaced about a year ago - should the brick work/plastering still be damp??
I am wondering if the internal plaster somehow "retained" the dampness. I only removed the plaster LAST week and am wondering how long the brickwork/pointing will remain damp.
I guess my question is "why is there dampness even though the roof was replaced a year ago"?
drying time, one year per inch thickness, therefore 2 foot wall = 2 years drying time.
I think you will find drying time is around 1" a month...If he goes by your workin' out 1John that would be 24 years :lol: :wink:
oops indeed, sorry for that, damn baby wont let me sleep and i am mightily confused in the mornings, midday, afternoons and evenings.
1 month per inch - 2 foot wall, 24 inches, 24 months drying time
