dual flush cisterns
2 Feb 2011
Bristol
I had a quick look at foxholes profile, i'm about to redo our bath room, before i start i must relocate the combi boiler downstairs in the utility room that wasn't built when i did the C.H. & plumbing, to fit it in the utility room i gotta move the washmachine out into the old part of the kitchen, to do that i gotta move the rad onto the opposit wall, where the doorway is into the conservatory, which brings me to the rebuild of the conservatory, WHY DID I BUILD IT SO SMALL!!
Where was i? dual flush, have you noticed on some makes the small flush sticks under the big flush & this can add to your water bill. :? :? :?
STALKER.
Solution: Don't get dual flush cistern, they waste water when they leak. And leak they will.
Get a syphon cistern with a variable flush.
Better still, fit a Fluidmaster flapper valve. Dual flush, variable flush and dead easy to service. Single button, so one half can't get stuck under t'other.
