Hi Guys,
I have a problem with my Ideal Standard Dual Flush Valve, at first I thought it was the button, rather than the valve. The problem is, when I press the small button (presumably for a short Flush?), the button stayed down and the Bit of plastic that has the teeth on it fell out. I have 3 toilets all with the same parts, so, I took off the complete lid from one of the other Cisterns and that did the same, so it's not the actual button mechanism, I had a look at the Dual flush Valve and the one that is causing a problem is facing a different way around to the other 2, so is that the problem? I did empty the cistern and remove the top part of the Dual flush valve, so see if I could put it on the other way around, but I can't, I'm wondering if it was put in wrong in the first place, as the house is only 4 years old. I think the dual flush valve that i have is either the SV89067 Dual Flush Valve, Product ID : ts212 or the SV92667 Dual Flush Valve, Product ID : ts243, info taken from http://toiletspares.co.uk/ideal_standard_37.html. Can I have your thought please. Is it possible to rotate the bottom half?http://toiletspares.co.uk/ideal_standard_37.html. Can I have your thought please, Is it possible to rotate the bottom of the valve?
Steve
Steve
