Ideal Standard Dual Flush Valve
10 Feb 2006
Essex
Hi Guys,
I have a problem with my Ideal Standard Dual Flush Valve, at first I thought it was the button, rather than the valve. The problem is, when I press the small button (presumably for a short Flush?), the button stayed down and the Bit of plastic that has the teeth on it fell out. I have 3 toilets all with the same parts, so, I took off the complete lid from one of the other Cisterns and that did the same, so it's not the actual button mechanism, I had a look at the Dual flush Valve and the one that is causing a problem is facing a different way around to the other 2, so is that the problem? I did empty the cistern and remove the top part of the Dual flush valve, so see if I could put it on the other way around, but I can't, I'm wondering if it was put in wrong in the first place, as the house is only 4 years old. I think the dual flush valve that i have is either the SV89067 Dual Flush Valve, Product ID : ts212 or the SV92667 Dual Flush Valve, Product ID : ts243, info taken from http://toiletspares.co.uk/ideal_standard_37.html. Can I have your thought please. Is it possible to rotate the bottom half?http://toiletspares.co.uk/ideal_standard_37.html. Can I have your thought please, Is it possible to rotate the bottom of the valve?
Steve
The buttons can be fitted either way around. So as long as the appropriate rods hit the right part of the flush valve there should be no problem. So turn the button assembly around if you have to!
The bottom half of a flush valve can only be turned around by removing the cistern
The top halves are usually OK to remove and refit in a different position but I can't say if that always applies.
http://toiletspares.co.uk/ideal_standard_37.html (Spot the difference :wink: )
Both units are held together by 4 lugs so a 180° turn should be OK, so long as it doesn't foul the inlet valve's operation.
Mine has only got 2 lungs, I did try to turn it around, but couldn't, let me see if I can take some pictures
Yeah, I did think about that, it means that the writing would be at the back. Ror the time being I have removed to rod from the small button to stop it catching and falling off. I was wondering if it was possible and if so easy to remove the small button to see why its happening?
