Ive been having issues with our central heating, mainly trying to get the downstairs rads hot (when the system worked you could hardly keep your hands on them !)
It has been suggested that the issue could be sludge or an airlock or a faulty pump. If you've read my previous posts then you'll know that most of the pipe runs to the rads is old, and so I've started to install new rads and pipework (in 22mm dropping to 15mm at the rads). However as its forcast to be -2 tonight I thought I would try and get at least the downstairs rads warm.
I drained the system. The water did have a slight tinge of blackness in it, but it drained down quite fast which would suggest that there was no blockage. I opened all rad vents to aid the drain down.
I then tightened up all vents and drain cocks and then turned on the water to the feed/expansion tank. When the tank stopped filling I went round and bled the rads allowing plenty of water to run into the bowl. I then turned on the electrics and set the heating running. After a short while the noise in the pump settle down and I used the bleed valve in the HW loop to bleed some more air out. I then went round each rad and opened the bleed valve again, venting a little more air out.
The pump works fine as I can feel the hot water progressing down the pipes right up to the tee that connects the rads (doubles) after the lockshield valve. Water is also squirted from the bleed vents so it must be flowing through the rad. However the rad still won't get hot, even though you can't keep your hand on the pipe the other side of the lockshield valve.
I've also noted that even though the thermostat is calling for heat (roomstat) and the rads are cold, the boiler sits there... then it might light anf run for a couple of mins and then switch off... even though the roomstat is still calling for heat.
Hopefully, when the new pipework is complete, which could be a few weeks away as I only have Saturdays to do it, the problems will go away, however I would like to hear what the more experienced guys have to say as to what needs to be looked at.
One thing I just thouht of, could the thermostat that sits on the pipe in the boiler (baxi solo pfl 60) be faulty and shutting off the boiler too soon ?
Malcolm
Malcolm
