Not seen these before. I've changed lamps in this fitting many times, never removed the gear tray!
I must say that I was not aware of them. Did they allegedly offer some advantage as compared with a "cheap as chips canister"?Saw shed loads in the 80's as I used to do a lot of commercial back then. A pain when they went wrong because instead of replacing a cheap as chips canister, the customer had to pay a deal more.
As on the fittings attached label, mainly for more reliable starting, the lamp has a slight delay to come on but they claim its no longer than the initial couple of flashes a normal starter does.I must say that I was not aware of them. Did they allegedly offer some advantage as compared with a "cheap as chips canister"?
Kind Regards, John
Was your experience consistent with that claim?All of which, they claimed, reduced the number of maintenance visits compared to a conventional fitting.
Everyone I know calls IR testing Meggering a circuit - I assume it’s more widespread than that.Note the use of the word MEGGAR I think somehow thorn were connected with them
Kind Regards, John
Yes, they are sturdy little beasts.Was your experience consistent with that claim?
Kind Regards, John
