whether the gas really does enter the property in a plastic pipe. However, if the answer to that is 'yes', then I'm not sure what you're going to 'test' - whatever resistance to earth internal metal gas pipework may have, it couldn't be an extraneous-conductive-part in that situation, and therefore would not require main bonding. Indeed, if it did have a fairly low resistance path to earth (despite a plastic supply pipe), that would presumably have to be because of other bonding and CPCs, not because of an intrinsic path to earth. Of course, those in the "if it's metal, earth or bond it" camp would do so, but others would then suggest that so doing actually increases hazards ... so take your pick, I guess
