Are you sure?If i have gas coming into the property (external)in non metal pipe
As for the water.and MDPE pipe for water(external)with plastic pipe internal. What are the requirements for earth bonding in a property?
If it really were true that the gas enters the property in plastic pipe (something I'm fairly sure I've seen, but everyone tells me I'm wrong every time I mention it!), there surely would be no need for main bonding, even if pipework downstream of the meter was metal?I'm sure it will be metal from the meter to your appliances and so will most probably need bonding - within 600mm of the meter or where it enters the building.
That's why I was cautious.If it really were true that the gas enters the property in plastic pipe (something I'm fairly sure I've seen, but everyone tells me I'm wrong every time I mention it!),
Possibly, but cannot tell without examination/testing.there surely would be no need for main bonding, even if pipework downstream of the meter was metal?
That's reasonable enough - but the OP seemed pretty adamant about the gas entering in plastic.That's why I was cautious.If it really were true that the gas enters the property in plastic pipe (something I'm fairly sure I've seen, but everyone tells me I'm wrong every time I mention it!),
'Examine', I agree - to ascertain whether the gas really does enter the property in a plastic pipe. However, if the answer to that is 'yes', then I'm not sure what you're going to 'test' - whatever resistance to earth internal metal gas pipework may have, it couldn't be an extraneous-conductive-part in that situation, and therefore would not require main bonding. Indeed, if it did have a fairly low resistance path to earth (despite a plastic supply pipe), that would presumably have to be because of other bonding and CPCs, not because of an intrinsic path to earth. Of course, those in the "if it's metal, earth or bond it" camp would do so, but others would then suggest that so doing actually increases hazards ... so take your pick, I guessPossibly, but cannot tell without examination/testing.there surely would be no need for main bonding, even if pipework downstream of the meter was metal?
That's all true - but cannot definitively say from here.whether the gas really does enter the property in a plastic pipe. However, if the answer to that is 'yes', then I'm not sure what you're going to 'test' - whatever resistance to earth internal metal gas pipework may have, it couldn't be an extraneous-conductive-part in that situation, and therefore would not require main bonding. Indeed, if it did have a fairly low resistance path to earth (despite a plastic supply pipe), that would presumably have to be because of other bonding and CPCs, not because of an intrinsic path to earth. Of course, those in the "if it's metal, earth or bond it" camp would do so, but others would then suggest that so doing actually increases hazards ... so take your pick, I guess![]()
